BroKen_H
Re-member
First final mix
laughings
I always get a kick out of thinking how good something sounds, until I put it up for scrutiny. Funny how things jump out at you immediately after you render...first few vocal lines need retracked and the vocals are boxy/dead sounding. I don't like the way the hats sound (not the tone, but the programming).
Listen to the end for me (well, as well as the whole). I'm trying to decide whether things should fade out like that, or drop off one by one...
Worked hard on the trumpet part. Hopefully it sounds at least semi-realistic. LP/Vox tones throughout. Standard acoustic work. Euphonic Zampled Strings. 10/18 Bass layout (same as all on this project). Played with some percussion samples.
Cold turkey on the vocal effect I usually use. Sounds odd to me. Only 7 notes pitch corrected, but it sounds like a few more could use it.
Remix based on suggestions:
