G
Greg_L
Banned
4ms latency
That's pretty negligible.
4ms latency
I read it that the sound of the guitar in the room bleed into the headphones so much that he had to turn the headphones up to monitor the click over the live guitar bleeding through the headphones. That got so loud that he needed ear plugs. Drummers tend to have this problem when their headphones don't isolate enough.Get the cans on turn them down, lose the earplugs, mute the guitar track in the cans (or turn the track down to a suitable level).
If latency is the reason, manage it with your buffer settings or totally mute the tracks.
If you're struggling to follow, try lifting on side of the cans off so you can hear mix and live, or try using direct monitoring if your interface supports it.
If you do the former and the amp is too loud (which it should be) pop an earplug in the open-ear.
Do what Greg does and turn off the guitar in your headphones. 4ms latency is the amount of delay you get when you stand about 4 feet away from the amp. It really shouldn't throw you off. It starts getting a little disorienting around 25 or 30msI can't be sure since it was my first time doing this, but I think it was the 4ms latency combined with the loud amp bouncing all over the room, which I'm not used to. I wasn't sure if what I was hearing was the amp from the cans or the amp itself and it was throwing me off.
At times I tried turning the cans off and just using the amp's sound. It was okay, but I preferred that ear plug method because it allowed me to turn up the drums/click in the cans and hear the beat better.
This was my first time recording loud guitars in a decent room so...a lot of learning and experimenting (and errors).
that's exactly right.
Something aint adding up here. If the amp was so loud that it interfered with tracking, then the pre wouldn't have to be turned up very much for normal tracking levels. This would reject the bleeding click track on a close mic'd cab. I'm thinking your amp wasn't actually that loud, your pre was turned up maybe way too hot, and/or you had your cans unnecessarily ridiculously loud and they don't isolate.
you have to realize i'm used to recording sims and hearing them right there in the headphones
Or, in the future, just stay in there with it and deal with it..
I will because it freaks me out that the mic picked up the headphones when I stopped playing. That alone is enough to never do this method again.
Lol. Well that's a different problem. The only "bad" method you seemed to do here is have your cans blasting so stupidly loud that you needed earplugs and you recorded the bleed from it. I mean really, all of that is asinine. But you live, hopefully you learn from it.
There are a number of ways to take the edge off, if necessary, but I don't know if there's a need with decent cans.
Do you think the mic would pick up that headphone bleed while I was actually playing chords at full volume?
Right enough...What cans do you have?
I don't fucking know. Listen to it and see for yourself. You're the one with the tracks. Lol. Dude.
