Bobbsy
Boring Old Git
Sony make fairly few great mics, USB or otherwise.
I've always liked the ECM 77 lav but that's about it.
That's right, thanksIt's probably NOT going directly to the HDMI output. USB mic inputs to a computer are almost always buffered in the computer. If you're adding an effect like reverb (pretty standard for karaoke) that will add to the delay as will any other effect you're using.
Good point!You may find you can adjust the latency on your computer, depending on your software. If you go the XLR route with an interface, make sure you get an interface that has ASIO drivers. These are specifically designed to lower the latency too.
Sadly, I think I cannot use this simple solution : (XLR Mic + PC analog audio ) > audio Mixer > AV receiver analog audio inputHowever, there will always be SOME lag running through a computer.
Are you using the computer because you want to record her karaoke or simply as a way to get an USB mic into your AV receiver? If it's the latter, another thing you might try is not using the computer at all. Instead, buy a basic XLR mic plus a small, cheap mixer. If the computer is providing the backing tracks, put that output into the mixer as well. If reverb is wanted, lots of pretty basic mixers will do that for you. Indeed, with the right set up you might even be able to feed the output back into the computer to record it.
Just a thought.
" an analogue Philipps mic ($50) plugged into the mic input of the audio card integrated to my motherboard with 3.5 jack : no latency, but the level is too weak, and the quality is not really good (as expected!)"
Aha! There IS a mic, the BM-800 about $30 that plugs in the motherboard jack as per the Philips but it is a capacitor (aka condenser) mic with good sensitivity and IMHO very decent sound quality (I am STILL waiting on son sending me some recording of his 2500 Euro classical guitar on one!)
Bit more money to spend but as Bobbs says, you can only really get low latency with an XLR mic and a decent AI.
https://www.amazon.co.uk/BTSKY-Cond...8&qid=1465204860&sr=8-1&keywords=btsky+bm+800
Thanks, but I fear the integrated sound card will be the achille's heel of the system. So weird I cannot find an USB mic with a decent ADC just for singing karaoke.
When my daughter asked for it, I said "for sure, let's buy a mic and that's it" !!!
---------- Update ----------
Thanks Dave!
Just a cotton pikkin'! You said that the Philips dynamic thru the ISCard gave no latency? If that is so NEITHER will the BM-800! It might LOOK like every other USB LDC you have ever seen but it ain't.
It is an electret cap' mic powered from the PC and I found it worked better than a £50 USB mic I had.
It comes with an XLR to 3.5mm TRS jack plug cable so you are good to go right out of the box. In fact if it does not work for you I will buy it off ya!
Yes, I now understand that I won't get any latency using an analog mic, but as good as the mic is, the IScard quality is really poor. I could buy this BM-800 but along with a real sound card.
My friend comes on wednesday with a proper XLR mic and his external sound card : FireFace UCX (RME Fireface UCX - Thomann UK)
How's about a conversion of the HDMI to composite video plus stereo audio > Amazon.com: COWEEN HDMI to RCA Converter 1080P 3RCA CVBS HDMI to AV Composite Adapter DHCP RCA for TV Stick XBox PS4 DVD HDMI2AV: Electronics . Send the audio to a small mixer into a stereo channel and have a conventional XLR mic plugged into a mic input of the mixer. Some small mixers can have effects such as reverb and delay which is good for karaoke. Composite video from the converter goes direct to the Pioneer VSX-529 RCA composite video in and stereo audio out of the mixer goes to the L/R RCA audio ins of the Pioneer VSX-529. A little more involved maybe, but gives more control of the audio and shouldn't have a latency problem.
This setup presumes your system has composite inputs that you aren't already using.
Might be able to find something like this used a bit cheaper....
Behringer XENYX 1002FX 10 Channel Audio Mixer 1002FX B&H Photo
Level of the mic input of the ISC is very low, I have to boost the gain way too much and then I get distorsion. I also ear some crackles.Well ! THAT is going to spoil you for everything up to Xmas! Super low latency, blindin' drivers, cracking converter cips. ...
Mind you, what EXACTLY is wrong with the ISC? I have had 4 laptops and run sound thru the OBS card in desktops and they have always been fair to middling? This i3 HP lappy upon which I type sounds rather good straight into my Tannoy 5As and I has a Blista works Toshy laptop that was not too foul either.
Integrated sound is bog all use for general recording, high latency as you have found and the MO is crap for overdubbing but the actual basic sound quality is not that bad I have found, equal to an iPhone?
Anyhoosywhatsits. The mic I suggested can still be used on an XLR-XLR cable. Plug it into the UCX, talk about "tail wagging dog"!
Don't forget to post!
Yes, that's a tricky way to achieve the mixing, good point. But sounds a bit oversized (2 more boxes) and honestly I'm not sure it would better than an USB audio interface like UM2 | Audio Interfaces | Computer Audio | Behringer | Categories | MUSIC Group and a traditional mic.How's about a conversion of the HDMI to composite video plus stereo audio > Amazon.com: COWEEN HDMI to RCA Converter 1080P 3RCA CVBS HDMI to AV Composite Adapter DHCP RCA for TV Stick XBox PS4 DVD HDMI2AV: Electronics . Send the audio to a small mixer into a stereo channel and have a conventional XLR mic plugged into a mic input of the mixer. Some small mixers can have effects such as reverb and delay which is good for karaoke. Composite video from the converter goes direct to the Pioneer VSX-529 RCA composite video in and stereo audio out of the mixer goes to the L/R RCA audio ins of the Pioneer VSX-529. A little more involved maybe, but gives more control of the audio and shouldn't have a latency problem.
You're right. The cheap Behringer interface uses Asio4all drivers. It may not be sufficient to avoid latency. This time, before buying I will clearly explain the purpose of the use.Careful of a lot of cheaper Behringer interfaces--they use standard Windows MME drivers rather than a purpose made ASIO so latency is still an issue.
I hear what you say about the internal sound card--mine is only really suitable for Skype phone calls--and even there I often plug in a USB interface. Internal cards rarely have much clean gain for mics and also rarely have much headroom.
Arcaxis' idea about the HDMI converter sounds very clever to me...
But honestly I'd prefer adding only one good audio interface rather than a mixer and a video converter.
So at the end, we may say :
It's not possible to find an usb mic suitable for karaoke.
Very surprising (or disappointing)
