L
lonlonmilklover
I have long been inspired by many to try performing and/or recording my Tuba through a Wah Pedal. After all, Bass Guitars and horns played through wah pedals and harmonizers can sound super cool:
https://youtu.be/2OL1_6AMw3Q (both bassoon and sax intros through cool effects right in the first minute!)
I do have the Cry Baby 105Q Bass Wah, which is optimized for bass frequencies, and it does work great w/ my Electric Bass Guitar as designed. However...
If I Mic my Tuba with a standard Shure SM57, and use a Radio shack XLR to 1/4" to be able to go directly from the Tuba to the Crybaby Bass Wah Pedal, then into my Pro Tools LE DigiRack 002, something odd happens. The sound I am getting has both a strong muddy and strong metallic tinny static sound with crackles and pops when playing - almost similar to the crackles and harsh sounds you hear when you are in the red, spiking your levels. However, according to the pro tools mixer - I'm in the healthy green, nowhere near spiking.
I have made sure all cables are snug and no devices are defective - other than my suspicions about that XLR to 1/4" adapter from the SM57 to the Crybaby, which I suspect may be my configuration problem?
I'm guessing perhaps the signal from my lungs through the Tuba into the SM57 into the XLR to 1/4" maybe is... too strong or harsh of a signal to go directly into the Crybaby?
I am so new at recording and playing with equipment though, that I don't even know the name of the device I might use to try to balance out or convert my Mic signal properly into the Crybaby.
I have browsed a bit online but I can't find much other than Jeff Coffin's actual list of gear: Gear » Jeff Coffin Music , so I'm "onto" something, but I just need a bit more education on how to understand if what would work for a Sax through a wah pedal would likely work for a Tuba. I don't see why not, since I have a Bass Wah Pedal and the frequencies are par, lol.
I think my biggest confusion is: Is that XLR to 1/4" adapter the root of my problems, and should I be using something called a "pre-amp", or rather a "DI Box?"
If I understand correctly, a "DI Box" would take my acoustic wild and crazy Tuba signal and tame its craziness to be more manageable before it goes into the Crybaby?
Sorry for so many directions of questions, I'm just reaching lol...
