ah. like a volume boost AFTER previous inserts, but BEFORE where the compressor is in the chain. so if a previous insert is taking away volume, this will add it back in before the compressor acts on it...? the input gain, that is
You've got it nailed now. Wow, we figured you
didn't have a threshold
ehh, throwing me off. "adjusting how much reduction you're getting" and "sweet spot" sounds like threshold to me. Either I need to go back to basics, or something is off.
No, you're real close.
I'll toss this in, might help in a few dif ways..
On a comp w/o a threshold (like we were talking about), they set them up- or their 'start point, would be the fixed threshold, and might start compressing a track at in/around 'normal' level.
You'd then raise or lower it's input gain to set the amount of compression. No dif in that respect than moving the threshold on one like you have.
Here's a 'bug I perceive with the 1176' style 'no threshold' comps.
Many times compression is only reducing a relatively small amount of the actual
volume of a track. So 'make up gain isn't even needed.
Now take this 'no threshold comp. If you have to raise the input for example to get this same compression, now you have
actually raised the track volume! and.. now you actually would need to do yet another adjustment- either there on the comp out level, or somewhere else.
Someone mentioned once that that '1176 style made fine sense- when you ' just grab it with both hands.. in a rack!
In digi plug land, ick. I don't want to have to 'juggle two things (and now add perhaps two lines in the automation..?) Vs give me the one threshold move, and let me get on with 'volume/levels of the track elsewhere- often track level automation for example already in place
All this leads to.. Also, check out
pre insert gain leveling automation. Here, you are trimming/fixing how the track sits in the mix, and you can anticipate / use it as an
option to how hard various points drive the compressor down stream.
