VomitHatSteve
Hat STYLE. Not contents.
Hello!
So I'm finishing work on a live album that I tracked in the summer, but as I review the mixes, I'm finding a lot of issues with vocals.
This song probably has the best examples of the problems I'm having:
Flight of Malibu pt. 3 (Live) - Regdar and the Fighters
First, we had pitch issues. At the start of verse 2 (0:40), the vocalist is about a semitone sharp for the first part of each phrase. I pitch shifted her down, but as you can probably hear it ended up pretty wonky. There was a ton of bleed between mics, so there's phasing between her track and her bleed into other tracks as well as the bleed from other instruments into hers. Any ideas how to fix this?
Secondly, in order to create separation between the two voices, I centered the first and then had the second (panned slightly right) essentially side-chain compress the first to move it left. You can first hear this around 0:13. Is it subtle enough, or is it weird?
Any other input you might have is appreciated too.
