ashcat_lt
The proportions of things going to the verb will remain the same. If you wanted those proportions to change when the faders did, you'd have used a post-fader send. As long as the fader for the reverb track comes down with all the others, there shouldn't be any difference at all.There you go. You learn something new every day, sometimes through trial and error.
I think the only thing you might have to adjust if you bring all your volumes up or down is the amount of send to pre-fader effects like reverb, for example. What I mean is, you're turning everything down, but the amount of reverb is the same, so it will actually end up giving you more reverb than you want since the dry levels went down but the reverb level stayed the same.
Post-fader sends WILL get fucked up, though. A reverb or delay will basically be turned down twice (at input and output), so will not sit where it was in relation to the mix. It'll also technically have a bit worse S/N, but in floating point land it's not enough to mention (so I did!
Also, you'd want to be careful that you're turning down only top-level tracks. If you're using a folder for a bus (with default of master/parent send on), and turn down the folder fader AND those of the individual tracks... If there's no FX on the folder, it doesn't really matter if you turn it or it's children down, but with FX it is exactly a post-fader send and everything I said above applies.
