trancedental
I've been helping another local poster on here who lives nearby, optionalanalog, with troubleshooting his system, slaving a MSR16 to a TSR8 via the Midiizer. The MSR16 loses sync after 12-20 seconds & then has to chase & lock again & again.
So first we checked the heads of the MSR16 with a jewelers loupe & an LCD torch, found a bit of tape debris but nothing serious, cleaned that away & tried again. No luck & the same problem as before, changed the custom made accessory 2 D-Sub cable for an original Tascam one & then tried my Midiizer without any difference. Cleaned the D-Sub socket & tried again, still the same issue.
We checked the Midiizer was receiving a valid sync code from itself by taking it's output & sending it to the Midiizer slave input connection & the signal was fine. So we called it a day & had a beer!!!
So I eventually located my TSR8 service manual today & found the page which details the adjustments for capstan / tape speed both when in internal & external mode. I luckily found a online .pdf Tascam MSR16 service manual http://www.tascamvintage.com/Tascam_MSR-16.pdf which had similar instructions to those in the TSR8 service manual. Which involved using a "flutter" tape @ 3K or so recorded tone & an oscillator to check the exact frequency being used by the machine & the 2 adjustment positions on the capstan / speed PCB.
Being aware that a flutter / wow measurement tape & an oscillator would cost serious money I suggested that I felt that the service company that checked & aligned his MSR16 a while back should perhaps have checked the capstan speed on the recorder. Optionalanalog has got in contact with them & found out that the capstan speed was not checked, luckily the company have said they will send us a frequency counter & instructions on what to test for, more toys for us to mess about with then!!!
We're also waiting on a reply from a guy from Tascam Germany we have been in contact with regarding the problems with syncing his MSR16.
Optionalanalog is currently trying use the MSR16 as the master & TSR8 as the slave to see if that makes any real difference as regards the sync problems
Hopefully we are on the right track towards solving this great mystery but any advice from the regulars on here would be more than welcome!!
