BroKen_H
Re-member
Okay. First mix of my newest song. See what you think.
Second Mix
Deleted
Third Mix: (replaced)
Second Mix
Deleted
Different to clear your head and critique your own stuff...
Schwarz! Keen. I went ahead and replaced the tube limiter with a C1-L1 with the attack set all the way to 1 ms and the release set to 300ms and good call on the drum roll. Grabbed that one roll and pumped the wave up without affecting the rest of the track. You'll see those in the next mix.
NTB: Thanks for the listen! Glad you like the song. Still working on the two guitar lines. Thinking of making them all on the same track. I'm using a different cab and a boost on the solos, but the same basic amp settings. Maybe I can play with the boost, or try the tube screamer I bought and have never used...Of all my fights, the electrics are my biggest.
Thanks Mike! Good ear! I played with the acoustics this morning. Automated the high pass to let more balls through during the intro and the Rhodes solo, then back up during the rest of the song so they don't muddy the bass line. Actually, no EQ, just thick fingernails. Strumming is easy with nails. Picking a solo like you're fingering a bass limits your speed a bit...well at least mine!The bass is an 18" with a 57 and a 2x10 cab with the 2001. The crossover set to around 800 hz and the top has a nice tube dist added. Maybe I should stop trying to relive the 80s sound and work with a modern cab sim...
I'll take a look at the cymbals.
Jimmy! Thanks. It's a labor of love. The kick actually has an 80Hz sub kicker to it to give it balls. Ben's idea with the 10k shelf really made it shine! I either need to run the bass as a single in from the 18 and skip the distortion or try some weird EQ trickery I guess. I kind of like the bass sound, but if the consensus is to reboot, maybe I'll just have to sit down and retrack with DI. Okay...the first comment I got about the guitar sound was the second solo had good tone, so I moved the first solo to it's cab. Maybe that was the mistake. I'll get it all on the mellower cab sim and play with the mike placement a bit. Brand new Kuassa package that I'm still playing with... I really like the tone of the background guitars, but yeah, there's something "bitey" about the leads. Like I said above, I might pull out the tube screamer (sim) and see what happens. Probably have to wait for Saturday. Then we'll get mix #3.
Thanks everybody. You are the best. Someday, I'd like to meet a lot of the people on here. If anyone's ever vacationing around the Outer Banks, let me know!![]()
