M
mhacker
Hello you guys, thank you in advance for helping me.
I've attached a 2D version of my room, because unfortunately I'm not familiar with 3D drawing. my room is a little bit strange. as it's been shown in the picture, it's not rectangular. so first of all, what should I do about the angles below or above 90 degrees?
the height to my room is 280 cm. I checked the dimensions in amroc - the room mode calculator and I saw its not that appropriate! should we consider the dimensions before we do any acoustical treatments or after installing them? with my room being that small, is it wise to make something like a vocal booth or a quiet room within the room? I was thinking about my options: I can reduce the height by installing what we call a "fake ceiling" (I don't know the exact term) or I can make a room within the room with this dimensions: L: 200-250 cm/ W:150-165 cm/ H: 240-280 cm. what should I do? I just need a decent room to record vocals.
the walls of the room (about 8-10 cm wide) are made of bricks and cement, without any air gap in between. but if I'm making a room within the room, I would use drywall (not sure if prefabricated plaster walls we are using in Iran qualify as Drywall!) with the width of 10cm, then a 5cm layer of air gap and after that I'll be using Rock wool (80 kg/m3) with 5 cm width ( rock wool 2*1 m panel slabs with 5cm width). I'll be using acoustic panel as needed after I install the rock wool inside the wooden (1*1m or 2*1m) frames. am I using the right materials? would you be kind to help me figure out what should I do?
