All hooked up. Played the demo...no problem. Plugged in guitar but got no sound.  What am I missing? Source H is selected. Plugged into H guitar line. Two monitors hooked up to balanced input. Thanks
First ... all faders down, including master, and turn monitor out all the way down ... I'm assuming you've connected your speakers to the monitor outs (not Stereo Out, which is the mains).
1)  Use toggle switch on rear to switch Source H to HI-Z if you have a passive pickup, or leave alone if you have active pickups
2)  Assign Source H to a track (do NOT assign to the stereo bus, because you'll forget you did that later!)
3)  Arm the track for record, the button will flash red
4)  Bring track fader up to 0db
5)  Bring Master fader up to 0db
6)  Slowly bring up Monitor Out ... be careful ... you don't want to accidentally blow those speakers!
That's the deal ... now you can hear yourself.  Don't forget you need to press the RECORD button if you want to record that track.
