rayc
retroreprobate
Man,
ancient doesn't refer to the early 1900s except, on occasion, when sneeringly used as a pejorative when referring to someone or something older.
It, generally, refers to times prior to the fall of the Roman Empire.
Being that modern history is usually deemed to have begun C1750 and Medieval history preceeded that perhaps early 20thC would be closer to the mark you were aiming for.
Had you read the linked reference you'd find the Great Depression as the catalyst for change in terms of dressing piano keys as well as giving you a chance to avoid presenting a misconception as fact.
It's always a good thing to read the resources you link to.
Even better to cross reference that information, (remember google & wiki are not valid research resources: the former being a tool that gives preference to paying clients and the latter being easily modified, based on false information or opinion though they strive to authenticate as much as they can), with at least one other sources that agrees with the information.
Sighting personal exprience is fine though - when you can back it up.
Anyway, I'd expect such rigid demeanours on a PRO STUDIO recording list. Which I wouldn't go on because I have nothing to do with it. But for crying out loud this is a HOME recording list. Anyway, I apologize for trying to help people. I can't be bothered with the Ivory now on second thought, it'd be too fiddly even if you could lift a nut or 2 off a decent key. I might just experiment with the theory another guy told me that the nut should be made out of the same material as the frets and try and engineer something out of Nickel.
