I was talking about just strumming the strings on the DE's and then doing then same on the fenders They were just golden in comparison. As I said that silly raised bridge isolates the entire stringmass from the body, go and compare one yourself if your LMS (Local Music Shop / Store) stocks Dans. it's abit of a snobby shop and they don't really let you plug in a guitar unless your seriously going to buy one.. Accoustic sustain is different to amp sustain.
well the never tele bridges without the 3 or 6 'barrels' on screws people seem to prefer the newer, cast saddles with grooves. A knowledgeable friend of mine reckons the vintage trems on Strats with the pressed 'humped' saddle without any groove for the string are the best, I mean the $5000 custom shop reissues have that 6 screw trem - if it works it works. I actually mistook your original comment for a strat bridge, but there is a definite difference on the cheaper squire strats with the tiny potmetal trem block when you switch to the GFS brass block or similiar. I'd like to try the wilkinson strat bridge that has the string end bobbins staggered to keep the string lengths the same. Anyway, I've gotten over my 'bling everything possible out' phase and just do things that make the guitar play better. on my jag bass I just fitted a Hi mass bridge (would have gone Bad Ass, but theyve halted production for some reason) and a graphtech XL nut, about $50 and yes, I did notice a difference in sustain over the stamped thin bridge. It's more than enough guitar (or bass) for me as I progress in skill.
Check out this site :
KGC Tele Parts . Now tell me how a small brass block under over an inch of ash, maple, or in our tele plus owner's case, pine is going to make any difference to your tone Lol, and don't even get me started on the titanium saddles, gee they must save you 5 grams off your tele, Eliminate those back problems! $105 what a joke. Check out their special 'compensated' trem claw and the tremolo system with 'proper vintage springs' you could spend a grand on that site, but gee, you'd have so much sustain that You'd trigger geiger counters every time you played. Just joking, what a way to waste all that money.For what they want for the KGC custom strat tremolo arm system it's over $300 if you go for most of the good options, for not much more. you could buy a decent squire like the Strat HSS blacktop or any of the Vintage Modified range of Tele Customs or the bigsby cabronita depending whether u like humbuckers. single coils or Wide Range HB's, you could even buy a Bass and have change. Actually I'm really digging
the John 5 tele in frost gold, if the australian distributor brings any in that is! I wouldn't mind replacing the neck pup with a Wide Range, they sound so country stock, I don't know why more country artists don't use them... it's a little known fact that Brad Paisley and Keith Urban are the only country artists that are allowed to play their own instruments on their recordings. And Urban earnt that much more through reputation than outstanding skill, I'm sure many of you could immediately name 5 players out there that could wipe the floor with him. oh well, this is going off into the shrubbery.
Anyway,I didn't want to get into an argument with you Muttley, Was just telling how the danelectro and fenders differed. As I said, if you get a chance, try one out and compare it to a fender.
Actually going back to nuts, someone said find someone who is replacing the keys in a really old piano and grab a handful of white ones if they are ivory that is. you'll have enough material to cut nuts for life.
