C
Ctoan
Hi guys,
Completely new to the site and i found this place by trying to google troubleshoot my issue, so i hope you guys can help. I have a behringer B112D PA speaker, i basically use it at parties, so people usually get drunk and try to change/ turn the music up fiddling with any knobs they can touch, which could be one of the reasons why it's broken. Anyway, the speaker wont boot, there's three lights that flash in sequence, the two input lights (green) and the power (orange). If it is left in this booting phase for long enough it will eventually turn (1-3 hours) and ive found heating it up speeds this process (i know that will make some of you cringe, apologies). I usually do it intermittently with a hair dryer or leave it out in the sun. Once it successfully boots it sounds as good as it did out of the box, and usually i can turn it off and back on again with out any hassles. however once it cools down again, the same issue will occur. Any ideas? i assumed it must have something to do with the soldering if heating it up helped.
Thanks
Thanks
