Odd E O
I was recently given a pair of Rane FPM44 program mixers without power supplies. The power supplies are no longer offered by Rane, and used ones are very expensive - if you can find them - so I am thinking of building one that can power both units. I have the skills/tools to do this, but lack the knowledge of circuit design to come up with a sound design. From what I have been able to find online, it should be a pretty straight forward, but I am seeking someone on this forum who can verify what I am looking at is sound and will work.
Copy of the user's manual...
http://www.rane.com/pdf/old/fpm44man.pdf
Here is the spec sheet for the OEM power supply...
http://www.rane.com/pdf/rs1dat.pdf
Using this transformer...
18V, 1.5A Center Tapped (9-0-9) Transformer - Power Supply Depot
Description of circuit (mounted in vented metal enclosure):
AC mains - switch - (?) amp slow blow fuse - ground (green from mains) to suitable point on enclosure, hot (black from mains) to black on primary side of transformer, neutral (white from mains) to red on primary side of transformer - yellow from secondary side of transformer to pins 1&6 of RJ12 jack, left blue from secondary side of transformer to pins 2&5 of RJ12 jack, right blue from secondary side of transformer to pins 3&4 of RJ12 jack.
Do I have this correct???
Thanks
Thanks
