TelePaul
J to the R O C
geesh i leave you lot alone for a few days and you all come up with this....:d
:d :d :d
They are guage .12-.53. I normally use .13-.56. Would that make such a difference?
Man....I can't imagine that change in guage would cause such a problem. That's not much of a change. And you say one of the strings actually ripped a peg out of the saddle? Wow.
What I meant was, for a given tension and length, a larger string will vibrate slower.
I'm not exactly sure how I could have worded it much better to get the point across without launching into a physics lecture. Given the OP somehow had it in his head that lighter gauge strings need more tension to get to pitch, I figured a full explanation would just confuse the issue...and I was typing on my phone, so I was trying not to be too wordy.and mass per unit length and elasticity. All are variable and will change the frequency.
A larger, fatter, heavier, string is less inclined to start into motion but it will vibrate at what ever speed it has to for that mass, length and tension. Part of string design and instrument design is matching the materials and intended pitch. There are lots of tension/length calculators out there. I have posted links to a few in the past.
Since he was putting the strings on the same guitar, the length didn't change (at least not enough to make 6 semitones of difference). I assumed that the new strings were the same brand and style, just a lighter gauge than the old strings were, so the difference in mass would probably only be because it's a smaller string and would therefore have less mass.
All things being equal, the heavier string will have a lower pitch and/or need more tension to be at the same pitch as a lighter string.
I wasn't attempting to help you. You obviously get it it. You are just nit-picking my over-simplified explanation.I'd be happy to receive your physics lecture... Maybe you would like me to grade it for you?
The strings wouldn't have to pull harder to get to pitch, they might just fret out because the neck is bowed back because the strings have less tension, and therefore won't pull the neck straight. (because the truss rod is set for the tension of the heavier strings)You still don't get it! Because the neck relief is set for a heavy gauge string, if you put a lighter gauge string on it, it will have to pull even harder. Muttley can explain this better than myself, so I'll let him do so, but you(Farview) are misunderstanding what is being said here. No big deal though.![]()
LOL! You get it! LOL! If the neck relief is set for lighter gauge strings then I imagine the tension would be the same as a heavy gauge string on a guitar with the neck relief set for a heavy gauge string.The strings wouldn't have to pull harder to get to pitch, they might just fret out because the neck is bowed back because the strings have less tension, and therefore won't pull the neck straight. (because the truss rod is set for the tension of the heavier strings)
I don't think so. The neck relief doesn't have anything to do with how much tension it takes to bring a string to pitch. The truss rod is set to keep the neck straight against the string tension, lighter strings have less tension, so you would need to adjust the truss rod for less tension to compensate.LOL! You get it! LOL! If the neck relief is set for lighter gauge strings then I imagine the tension would be the same as a heavy gauge string on a guitar with the neck relief set for a heavy gauge string.
Yeah I just ordered new strings.
They were about 6 semi-tones flat and felt like they were going to break. One string actually ripped a peg out of the saddle at one point. I thought they might not be seated right in the saddle, but it looks fine.
I should clarify this is an acoustic guitar not a bass.
Now we're back to where we were. LOL! On a guitar with the neck relief set for heavy gauge strings, if you put light gauge strings on the aforementioned guitar without re-adjusting the neck, the lighter gauge strings will have more tension on them to bring them to pitch than the heavy gauge strings. However, if the neck relief is set correctly for whatever string is on it, I'd think that the tension would be equal. I might be wrong about this part, but I'm right about the first part. Muttley will know for sure though. What's your take on this Muttley?
