T
toasterman
Hi everyone,
I've been recording a speech-based podcast for a while, and it WAS fine, but recently I've changed some bits and it sounds worse, so wondered if anyone could help?
My audio equipment is: 2 x Samson C01 condenser microphones, connected to a Behringer Xenyx 802 mixer.
I was just running a cable from the headphone output on this mixer, to a line-in port on a HP Laptop and recording in Audacity, and that was fine. Over time, the laptop got old, it got problematic, it ran Windows XP, and so recently I replaced it with a Macbook Air. Because hardly any laptops seem to come with line-in ports anymore, I bought a Behringer UCA222 input device, and currently record to the Macbook with Amadeus Pro. I've used Amadeus a lot before on another mac and never had a problem with it, so I don't think that's the issue.
Since I switched to this new setup, we've started getting popping/clicking showing up on the recording. One recording session will be fine, another will have clicks in it. One time there was a strange type of interference noise on the recording that occurred when we were speaking, but not when we were quiet. The next session, fine again.
To try and pin down where the problem is, I dug out an old Minidisc player, and added that to the system. So for the last few sessions I've been recording multiple versions of what we do. The minidisc player connects to the headphone socket on the UCA222 device, the Macbook records via the usb interface.
First two sessions, fine. No difference.
But on the last one, there are noticeable clicks. In some cases, the click is on the minidisc recording, but louder than it is on the direct-usb recording. In most cases over a space of 20minutes worth of audio, the click is only on the usb one, and not on the minidisc one at all.
I have tried connecting the UCA222 to another mac. I recorded for 30+ mins, with no noticeable problem on the recording, but as I say it doesn't do it all the time anyway. That needs further testing.
Does anyone have an idea which bit might be the issue?
Could it be that the macbook air just isn't very good at recording over usb?
Is it likely to be the UCA222 (which as far as I can see has quite positive reviews online)?
Could it be something else causing issues in the system that is generating a minor issue which is massively amplified by my new setup?
Thanks for any help you can offer.
Ben
Ben
However, please bear in mind that I know nothing about Macs.
