PDP
There once was a note
What is a "summing" mixer, and how is it different than a regular console/mixer ?
...and decided that running out to the analog world one last time would magically fix everything....
Summing is a relatively new buzz term used to sell you something you didn't know you needed, and probably don't need. Yeah, the basic models are not much different than a good line mixer. I'm all for mixing OTB, so using an external mixer with analog sends, EQ, etc is a good idea IMO. And to be fair many devices pitched as Summing mixers are geared and have features helpful for people that have never seen analog tape or analog mixers. The best are designed to make it easy for you to use ourboard gear with a DAW that would otherwise be totally ITB. But most good mixers could do that. It's just you children are so far removed from real recording that manufacturers take advantage of your ignorance and sell you something with a different name... summing vs. mixing, when you could just as well buy a good line mixer or console and have a better product. That's the sad truth.
I hear people say this, but I don't understand how it is even possible, without some sort of setting snafu. The playback you are listening to is being summed digitally. Storing it as a file really shouldn't change anything because the summing doesn't change.You make it sound as if using a summer is a waste of money and only for the naive. On my system, the difference between digital and analog summing is day and night. Even my 7 year old niece can hear the improvement through the summing box.
I'm not saying that it is for everyone. I'm just saying that it solved my problem. (The final mix-down process in my daw was causing a noticeable loss of quality. The final print version sounded different (far worse) than the playback did during the editing and mixing stage.) Now it sounds similar. I am finally happy. I'll never go back.
I have not had this happen unless I was rendering it to the wrong file type/bit depth/something.
I think that might be an example of someone coming up with a theory that works in their own head, but has no basis in reality.
Just like you don't have to know how your automatic transmission works in order to operate a car.
It really is that easy, actually. This is ancient technology. All of the designs have been tried and tested for half a century. All this dude has to do is tweak an R here, a C there, "compare" various mojo parts until he decides it sounds good.Well...the reality is that tube amps DO sound better than transistor amps!
His amps sound particularly good...so he must have uncovered some "truths" in the designs. I mean, I doubt he just guessed at it and got lucky.
Next time you're at the shop, ask your mechanic to explain the physics behind the operation of the transmission.Yeah....but you would is you were building a car.
He was building amps....not just operating them.![]()
Again, he doesn't have to know why.Well...the reality is that tube amps DO sound better than transistor amps!
....his explanation of why tube amps sound better than SS amps is nonsense. Anyone that remembers high school physics should be able to recognize that.
You like getting you R's and C's tweaked, don't ya? You pervert.Rs & Cs...tweaking....... "tweaking an R here, and a C there"..........
tweaked Rs & Cs..............
