Cool man. For me, the DSL Green Crunch mode is where it's at. If I had one, that's the sound mode I'd always use. Sounds great on the big versions.
Yep, from what I've read it goes from slight breakup to just a little dirtier than AC-DC tones, which is about what I've been after on a few of the songs I'm working on, but I'm having a hard time getting there with the red channel, due to it having so much gain....When I turn the gain down to about where it needs to be, it thins the sound out so much, it doesn't work...If I use
the green channel, I have to boost it with an od, & even with mild settings, it kills the low end/chunk, so if/when I get the crunch mode installed, it'll see a lot of use too IMO...
So let me get this straight, The DSL has "Classic" and "Ultra" channels. You're installing an "Ultra" toggle is gonna switch between stock, and a lower gain Ultra channel setting? If so, that will probably be perfect. I would think, knowing your style, that you'd want more gain than Green Crunch but less gain than the typical OD side of the amp.
Pretty much Greg...Stock, my DSL-1 has the "
Classic" channel, which is the green clean channel on the big DSL's & the "
Ultra" channel, which is od 2 on the big DSL's...The mod I'm working on would make
my Ultra/red channel into the big DSL's red channel, with od1 & od2....Installing the toggle switch would make it the same as having the od1/od2 button on the big DSL's...
One thing you may wanna ask about is if those caps have any effect on the tone besides gain. Caps, depending on their value and location in the circuit can alter the lows or highs. I don't know if the caps you're tweaking have that affect. I'm just thinking out loud. People commonly snip the "bright cap" out of Plexis and 2203/2204s to darken the sound some. The bright cap is a different style capacitor in a different location, but yours might give a similar affect maybe? I don't know. Look into it.
AFAIK, the caps I'm gonna tweak/un-solder don't have any affect on the tone at all, except the gain...I'm already ahead of you, but the guy hasn't replied back to me yet....
The next step of the mod is pretty simple, but I'm gonna have to order some extra caps (just to have in case I fuck something up....right now, the C41/cathode resistor bypas capacitor that I took out, is still in tact/would work, but I wanna have a few on hand just in case), a few different value resistors, & a couple switches...Gonna get it all at once, but do the mods in steps like I mentioned...
And I'm sure my little DSL-1 would have a bright cap, just like the rest of 'em....I can't remember the exact board numbers, but they're all differnt in the different DSL's (IE: the DSL 50/100 is different from the DSL40, the DSL15 is different, etc)...
So, for now, I'm playing the waiting game, but I'm betting that to add the crunch mode to the green channel is as simple as wiring a different value capacitor to the green channel's gain stage (which would raise it, giving it more gain), snipping one leg of 2 caps (just like in the red channel that I'm working on now), & wiring it all up to a switch, where I could toggle/switch between the stock version & the higher gain version of the green channel...I'm starting to understand this stuff a little more, I'm not positive about this, but it does make sense to me, since that's basically what's being done on the red channel...We'll see...
