hawk
When I record a track to a metronome then play it back, the timing is slightly off between the two. Also when I record a second track and play along with the first, the second track is slightly behind the first. I assume this is due to latency correct?
So I have 2 quesitons.
1. What settings should I change, either in the Delta Control Panel, or in AA to make the latency as low as possible? I know I can never get it to zero but I just want to be sure my settings are optimized to get as little latency as possible.
2. How can I measure how much latency I am getting? I have seen people post their latency so I'd like to do that and see if I can improve it.
Here is my setup:
acoustic guitar --> condenser mic --Behringer UB802 mixer --> delta 24/96 --> Windows 7 64 bit --> Adobe Audition 1.5
I have the delta buffers set to 64 and the bit rate to 44.1
Thanks
Here is my setup:
Thanks
