brassplyer
What do you think of this DIY Reflexion filter design?
Making A Homemade sE Electronics Reflexion Filter For $50 Part 1 of 3 - YouTube
The short version is he makes 4 panels which have these layers in this order:
-Stiff felt
-dowel rod for air gap
-aluminum foil - supposed to absorb/block low freq
-cotton balls
-wool khaki felt
-Soft felt wrapped and glued around previous layers - this is the layer that faces the mic
All mounted with velcro to a sheet of Lincane perforated aluminum.
How would you expect this to perform compared to an SE Electronics Reflexion filter which it's supposed to emulate? I see that the actual SE Electronics unit has the backing layers as continuous pieces across the whole width, rather than all incorporated into individual panels. Also the SEE unit has an additional layer of perforated plastic.
Do you have a DIY design you like and know works? It's my understanding an overly simple one like just a layer of black A/C insulater foam over bent paint screens which are common online isn't adequate because it doesn't do anything about low frequencies.
What about A/C insulator foam over a layer of rigid fiberglass?
Thanks.
-Stiff felt
-cotton balls
-wool khaki felt
Thanks.
