Kash Meer
Hi everyone...im new to audio recording...im about to follow a course on audio engineering also...i wanted to know which D.A.W can i buy?a very good one...
Reapers as good as any IMO
I really like Cubase too. Although my versions old
thanks Bobbsy...personally to u,which one has the better interface?i still see cubase...and which one is easier to u for a newbie to start with?
I would say that none of them are necessarily easier to learn. Each has it's own way to approach things. Some just work better for certain people.
I started my learning with Cubase. After a couple years with it, I tried Reaper. It just did not work for me, BUT that is not to say it was not a worthy DAW. I was just already set on the workflow that I had spent so much time with already.
A bunch of 'you' working with trials of the different DAW's as you learn, will be a great benefit to you. I wish I had been a member here when I started. So many here have taught me so much since.
Likely a audio engineering course will teach you Protools. Sorry to any other users of the program, but I loathed every moment working with it previous to Cubase. That is just my opinion though. You decide what works for you. Not the opinion of some internet forum hack like me.
Either way, you will have support from members here regardless of which DAW you decide to use. Or even while experimenting with multiples.
Pick one. I have not heard of any that doesn't. Cubase does very well with MIDI.
Hey jimmys69 or anyone else,all i need now is to buy a new pc...can u advise if this PC will be ok?
Specs:
ASUS H561-E /USB m Board
Intel Core i5 Processor
8GB DDR3
1TB Hard Disk
USB Key Board and Wireless Mouse
Gaming Casing
Graphic Card Asus En 210 w/1GB DDR3
24x DVD +/- RW
22inch LED Monitor
24 Months Warranty
OS(optional)
That keyboard should work fine with Cubase and decent enough to get started.
Again, you should find out which i5 you are getting. The 4 core models will give you more processing power to play with.
