gentlejohn
OK, either I'm being really daft here or Tascam made a manufacturing mistake (so I guess it's just me being really daft!) I'm STILL trying to decide on my best way of hooking up my two external effects units to my 388. I want to use my Reverb unit as a global effect via the AUX Send/Return & my Tape Echo unit running through the EFFECTS Send/Return. Sounds straight forward enough so far.
For the EFFECTS Send /return I'm taking a 1/4" cable from the EFF Send 1/4" socket Output on the back panel going into the 1/4" socket Input of my Tape Echo machine. I'm then taking a 1/4" Output from the Echo unit into one of the EFF Return 1/4" inputs on the back panel (there's two 1/4" socket returns to choose from). I'm okay so far but here's the bit I don't get ....
I want to do exactly the same with my Reverb unit (ie: use it as a global effect across the channels) with the AUX Send/Return but I can't find where to return the signal. It's obvious with the EFFECT LOOP. There's a clearly marked EFF Send 1/4" output with two clearly marked EFF Returns 1 & 2 but, although I can see a clearly marked 1/4" AUX Send (it's right next to the EFF Send on the back panel) I can't find one 1/4" socket AUX Return.
I have noticed there's a AUX Buss RTN RCA input but where's the 1/4" sized socket AUX Return. My Reverb unit has both 1/4" In/Out sockets plus XLR In/Outs. Am I missing something here? It shouldn't be difficult to hook up this peripheral stuff I know! Bear with me .... I'll get there (eventually I hope!)
PS: I also have a compressor mono/dual I'm looking to hook up although probably just as a channel insert on individual sources whilst tracking (then again across the Stereo Output on mix-down perhaps). I just mention this in passing.
