M
moresound
Loud Sun Studios
And I take it that you don't have any other equipment such as a little "live" mixer to test the 770 on.
That hasn't done anything, well it was worth a tryGotta say, thanks again for all the help and time you've given me tonight. Is there any reputation system, so I can upvote you?
I'm in the UK, it's 18:20 here right now... I've been awake for around 45 hours though, so time is kinda lost to me at this point.Added some repI'm in the UK, it's 18:20 here right now... I've been awake for around 45 hours though, so time is kinda lost to me at this point.
This is a problem I had with a Tascam US-144 mkII interface and condenser mics. The USB port on a couple of my computers didn't have enough juice to power the interface when the load of the condenser microphone was phantom powered. The condenser mic signal was really weak to almost nothing and I had a bunch of noise in the signal. A dynamic mic was OK as well as a guitar or other device that didn't draw down the phantom.
What did work was using an axillary phantom power supply box or a powered USB hub, which sort of sucked. Probably you'll get a better idea of what's going on when you get a guitar hooked up. If you have any other USB ports on your computer give them a try and take off any extra USB devices that you don't need plugged in leaving just the mouse and keyboard. This may not be the problem, but something to consider.
Edit: You posted while I was typing.... maybe you've found something
I'm a student... I'm used to it xD
Decided to open up the cable... it's not soldered correctly xD Plus it looks like it was soldered by a blind gibbon! I was doing better jobs than this at the age of 7>.<
It's from some shop on ebay. Well it's soldered in a way that makes it unbalanced, not how an XLR to XLR cable should be soldered.
