Lt. Bob
Spread the Daf!
^^^^^^^ this ^^^^^^^^^^^^The same goes for a lot of things in audio. Some people just seem to feel that they HAVE to use a computer to do something, even if they're not quite sure why they need to. .
You haven't read the whole thread. Personally, I've been saying "do what though wilt" the entire time. In response I've been told that what I do is quite literally invalid. Whatever...Lt. Bob said:Look ..... the ones getting defensive in this thread are the sim-guys. Everyone who prefers tube amps has said that 'if it works for you then go for it" ...... and I'm positive that we all feel that way.
You had it right. Was the other guy failed the test.Greg_L said:Wasn't me. I didn't read your post.
You don't, but if you're going to continue to insist that there is a difference, and that you can tell...miroslav said:....why the heck would *I* need to convince you.
Oh believe me I have. The reasons I jumped into sims as soon as it was economically viable are still the same today, and considering that today's sims sound so much better and are so much more flexible than back then, I'm even further from going back.You said you stopped using amps something like 15 years ago (I think that's what you said)....maybe you should plug back into one and convince yourself.
I've read every word of the thread ...... and I certainly haven't even alluded to the idea that what you do is invalid.You haven't read the whole thread. Personally, I've been saying "do what though wilt" the entire time. In response I've been told that what I do is quite literally invalid. .
.......but if you're going to continue to insist that there is a difference, and that you can tell...
But...I'd like to mention that there are a whole lot of things that people do with guitars, and tube amps aren't particularly good at all of it.
Guys ...... once again I find myself pointing out that it's about the music you create with it.
Sure ... there are some people who don't seem to do anything but show how good they can get whatever sound they're after in a clip and that's as far as it goes.
But for most of us, hopefully, there's some ultimate goal in mind musically.
For me it's about live playing most of all.
For most of you it's the recording arts and getting a good tune and performing/producing it well.
Either way ..... I don't get why people get SO worked up about this stuff.
I have a LOT of nice amps and guitars ....... I don't give a shit about any of them ....... they're just tools for making music.
More and more big name people are making the switch over to things like the Axe Effect II. Huge stacks in smaller "venues" makes absolutely NO sense whatever!!
Yeah....it kinda does!
Yep. I've got several albums that I should be working on, but here I am...See Bob, here is the deal. I am sitting in front of my machine, thinking, man I need to really write and record. I am not progressing my next Opus. Then I come here and well, I get side tracked, I get to delay what I really need to be doing.
Besides, I don't have cable and this is a as close to reality TV I can get and it is less rehearsed/scripted (but it is predictable most of the time).![]()
In fact, I just spent way more time than it's worth building a little experiment that I find particularly informative. Don't expect it's going to change any minds or convince anybody, but here it is. Sound clips which I think are far more meaningful than that weird thing above.
So what I did was to record the exact same performance through both my Vox AC4 (with an SM58 straight in) and the AC30 model in PodFarm 2 (with a "57 on axis", which is close enough to the same thing). There is no real studio trickery here. I used the "amp controls" on the sim to try to match as closely as possible the sound of the real amp and didn't add any EQ or compression, with two important exceptions:
1) I recorded a segment of the amp/room noise through the mic with nothing playing to mix in at the same level as the mic'd track. Else it would have been pretty obvious which of the tracks was recorded through a mic in a living room with the furnace blowing.
B) The closed cab model I could find was the 2x12 that goes with the AC30, and it has an extended bass response which I thought gave it an unfair advantage compared to the single 10 in the AC4. So I slapped a high pass on there and tweaked it carefully to remove that added girth without affecting the rest of the tone.
No, the performances isn't anything spectacular, though I tried to go through a range of dynamics in my playing, and go up and down the fretboard a bit. Yes, it's just lame pentatonic crap. Since most of you seem to be coming from a blues/rock kind of place, I figured it was fairly appropriate.
Vox/PodFarm Stereo
has the tube amp on one side and the sim on the other. Tell me which is which.
Vox/PodFarm Mono A/B uses a square wave LFO to autopan between them, which is then summed to mono. Can you tell when it changes?
Now, I'm fully aware that this is nothing like a scientific test. I certainly don't expect it to change any minds, or really convince anybody of anything, but it's there, FWIW.
I couldn't care less what it comes from!!!!! It could come from a damned iPhone as far as I care. If it sounds better than a stage full of crap then so be it. I love a good tube amp and I have one. But I can make certain amp sims (not all) sound good too!! I've played tons of gigs w/o amps and I have had not one stinking person (even musicians that I know) come up to me and and tell me how bad my tone was. In fact...I've had several come up to me and told me how good it was. I'm a pretty good judge of tone....if it's good and comes from an amp...great. If it comes from a processor....that's great too!! Just my opinion though.....but, lots of big namers making the switch to smaller more compact stuff that can sound as close if not better than 2 or 3 amps on stage reaking havoc volume wise on the "venue" owner and patrons!!...much less the other members of the band. Volume wars suck!
Bullshit!! I've been in plenty good bands with plenty good players and great equipment! There's no maybe about it. We sound a helluva lot better without the 2 halfstacks and a million watts of bass power!! Sorry dude...just the real dealio!
Yeah...I know man. Don't really care whether you believe me or not and I ain't mad either.....but, lots of big time guys going over to things like that Axe Effects 2 and they don't seem to be having a problem with it.....and it sounds freakin' awesome!!! And the list keeps growing. The old guys will never give up the 100 lb amps and stuff....until they're too old to haul that crap around! Later!!
