G
grunshaw
Hi guys,
I am new here, so hi to everyone!
Secondly, I want to pick your brains about a situation I have and how to fix it or enhance it.
So first, at my church I run the sound and I am in charge of setting it all up etc. The equipment we have is ancient and also there are some new things thrown in the mix, like our Aviom in ears which is awesome.
We have a 32 and 4 bus mixer. I use the 4 bus to send some audio from specific instruments to a Focusrite Scarlet 18i6 audio interface. The interface has 8 inputs, so we are only utilizing 4 here.
My idea was to take some instruments and vocals directly into the unit, such as drums (which is an electric kit) and the two lead singers which can go straight into the 2 preamps on the Scarlet.
Right now, all instruments and vocals are sent via the insert jacks on each channel via TRS cables to the Aviom in ear system. I thought I would be clever (and obviously I was not) and I got some TRS splitter cables. They have 1 TRS jack on one end I inserted into the channels I wanted to take direct audio from and on the other, they have two TRS female sockets. I then plugged in a TRS to one to send to the Aviom and a TRS to the other to send to my Scarlet.
Wahay I thought, until I tested some things.
I found that audio was still going to the Aviom with no problem at all, but not coming through the main desk and out the masters. It's as if the channel was muted. Couldn't even hear the channel on PFL. I also couldn't hear anything via the monitors on the Scarlet audio interface.
So I started unplugging stuff. As I did, I heard something in the scarlet monitors. That prompted me to mess with the cable. If I balance it half with in the socket, we get sound, all be it bad quality.
That prompted me to switch the cables that run from the splitter to the scarlet with TS cables instead. That worked. suddenly I was getting audio from the drums fine, but not the vocals. I am guessing that is because I was capturing the right side. Still no sound on any of the channels I was attempting to split.
So now I am stuck.
I think you can draw a conclusion on what I want to do here and the lack of funds available means I can't just get a mixer with more subgroup and buses.
Just for reference, here is what I have.
Bass Guitar >> Sub 1 & 2
Drums >> Direct to Scarlet
Violin >> Direct to Scarlet
Piano >> Sub 1 & 2
Lead guitar 2 >> Sub 1 & 2
Lead Vocals 1 >> Direct to scarlet
Backing Vocal >> Sub 3 & 4
Lead vocals 2 >> Direct to Scarlet
Lead Guitar 2 >> Sub 1 & 2
Extra Guitar >> Sub 1 & 2
Backing vocals 2 >> Sub 3 & 4
Backing vocals 3 >> Sub 3 & 4
The idea is that I can mix things at a later stage if I have lead vocals, violin and drumson their own channels.
These all have to go to the Aviom too - so this is why I drew the conclusion I could just split the cable.
What can I do? How can I acheive what I want in the easiest and cheapest form?
If you have any questions about anything I have not covered, or need extra info,do ask.
Looking forward to your help.
James.
So now I am stuck.
Piano >> Sub 1 & 2
James.
