I'm curious how people here place/eq/phase align their overheads. With the glynn johns method I get good sounding toms and cymbals. But when they are loud enough in the mix the snare starts to sound like doo-doo. Therefore I am trying a spaced pair next time. Do any of you phase align drums to the overheads or roll off lots of lows/mids and use the overheads as cymbal mics? Just curious how other people skin the cat.
I've mic'ed oh's in 4 different ways (mono, spaced, X-Y, and RecorderMan), but I have a preference for spaced in most applications. Reason being is that I find spaced (if done all in phase with snare/kick of course) offers me the most accurate image to my ears and clearly separates the L and R sides of the kit, so it can be nice and wide - but if you want them narrower, do so via the mics and rely less on narrowing the panning - phase is better that way.
I normally use pencil condensers because, come mix-time, I tend to do a gentle high pass somewhere around 100 hz and end up taking out the frequencies that sound muddy or boxy to me, so I don't need mics with a massive low end body (or else I'd use LDC's or ribbons which are also great). I will usually track them cleanly on a fairly transparent pair of preamps with the low cut on the pre around, say, 50-60 hz.
Before doing any eq'ing or any processing at all, I will put both tracks at unity gain and send the outputs of both the L and R mics to an single stereo aux and process it there (I'll hide the 2 individual tracks but keep them active). The only processing I ever find I need/want on the stereo OH track is a multi-mono eq but with the settings the same on both sides. I always tend to reach for the URS API eq emulation. The 4-band version is fine for that application and instead of using a "low pass" knob (since it doesn't have one), I'll just do a low shelf cut at 100.
Oh seldom occasions have I ever compressed the Oh's, but if I do it would be if the crash cymbals are a little swishy and too in your face compared to, say the ride and hats in the picture. I don't use ride or hat mics barely ever, so evenness is important to me in the OH's. So I'll set a side chain eq on the compressor for the certain "pain" frequencies those loud crash cymbals are shooting out. I prefer a fairly transparent compression to achieve this, so no character compressors - just the standard Avid Comp/Lim Dyn 3.
The last thing I ever do is send a bit of them to the main reverb(s) I am using on my mix. I usually have a short room reverb for early reflections and then a plate for a longer tail and a crispy air. So I'll send bit of the OH to either of those or both to taste.
I don't phase align the close mics to the overheads! Having that slight delay from the close mics to the oh's and the rooms is the whole point of achieving depth and space with your drum mics. It sounds unnatural to move around the waveform later if everything was already recorded
in phase to begin with.
I think I've rambled enough. Hope that enlightens you! YMMV
