S
superelixir
I'm looking into some stereo delay/reverb type effects for my guitar rig, and I've come up with two possible ways to record them:
1) use two identical (or similar sounding) amps; route left channel to amp #1 and right channel to amp #2
2) use only one amp; route left channel to amp #1 and right channel to DI. After the take has been recorded, reamp the clean DI signal through the amp, and line it up temporally with the original recording.
Obviously the first option is ideal--the left and right channels would exist in the same space--but also more costly, because you need two channels of amplification. How close does the second technique come to the first? Assuming the DI signal is recorded at instrument level through decent quality converters, is there any reason this technique wouldn't capture the stereo effect?
