S
		surjer
So my 2488 has started to experience a new problem which is a "noise" that I can only chalk up to the preamps. Thing thats weird is that it does it on every channel on every input. If I arm a track for recording it gets this nasty noise. Its not super loud but its there. I am recording in 24 bit mode and using the same power source as before but i've experienced this noise no matter what location i take it to. Doesnt have to have a mic plugged in to get noisy either. I have cleaned it pretty thoroughly with contact cleaner and that has not fixed the issue. I did have a problem with the little rubber grommets coming out of the XLR connections on the back but I just popped em back in. They got stuck in the XLR cables somehow. Its a pretty tight fit... Any idea's? I have formatted the hard drive and cleaned everything out short of taking it apart. If there is a known trouble spot i am not against taking it apart i just dont want to take it apart with no idea of what might be wrong. (Maybe I should just do it tho?)
		 are you 2 guys using both the 2488(MKI) unit are what??
