T
		tevans213
Does it require a preamp?
			To expand on what Joshlew said, if you have an SM7B the pre amp you use (whether it's built into your interface or a stand alone unit) needs to be on that provides lots of clean gain. The output of the SM7B is very low compared to other mics and the pre amp needs amplify it a lot. Some pre amps get a bit noisy when you crank them up enough for the Shure mic.
I'm sure people here can recommend suitable hardware if you let them know a few more details--I can't help hugely because I don't own any mics that need the amount of gain the 7B wants.
			No doubt. But I was just wondering if could you in some cases get some improvement at a lower preamp gain and make it up later?Once the pre amp noise is present and audible, applying digital gain also raises that pre amp noise though. Best to get things to an appropriate level before A to D conversion.
			I have always wondered what the deal is with preamp gain for the SM7b. My Tascam unit works just fine with it, though the specs say 60dB of gain. Yet, when I use it for hh, I barely turn up the preamp. Even with vocals, I am barely running the X73i input gain to run it. I am starting to wonder if it is a conspiracy brought on by Aussies that just don't like the mic....
lol!
Seriously though, I have never had an issue with low levels from the SM7b. Maybe I just have a bunch of loud sources....
			Give this one more shot but rephraseIf only that would work it would make everything so much easier but, alas, no. Once analogue noise from the mic or pre amp is digitised, applying digital "in the box" gain amplifies the noise as much as it does the desired signal.
 The question is can pres have better or worse s/n performances depending on their gain settings? If (maybe) it's yes at a lower gain setting, maybe then we could get some improvement letting it come in a little lower at the A/D?
