RecordingMaster
A Sarcastic Statement
Hi there,
I am "mastering" 5 tracks for my band's next demo...hence the reason why we don't have the budget for actual mastering on this project. It's just an EP and everything is done on our own for this one -right down to the graphic design and cd pressing, etc.
The 3 earlier-recorded tracks were all recorded at 24-bit / 48k in different software. So the song's exported state will be 24 bit/48k wav file.
The 2 later-recorded tracks were done on a newer/better interface at 24 bit / 96 k. So those songs have been exported as 24 bit / 96 k files.
I want to bring each of these into a PT session to "master". Basically applying some very minimal broadstroke eq to match each tracks high and low end the best as possible to each other, bus compress and limiter for loudness (these plugins all separately applied to each track). Done. That being said, what shall i do about the sample conversion? The session will be started at 24 bit / 96 k. So when i bring in the 48k tracks, I assume I should have PT upconvert them? I just didn't know if this would do anything to the file or not,since you can't make chicken salad out of chicken shit. As in, upconverting a 48k file to 96 wont suddenly improve it, but I assume i MUST do so in order for those tracks to even get into this 96k mastering session.
I need them all in one session so i can easily switch back and forth to each track in order to A/B everything to make sure the EQ and loudness are all equal.
What says y'all? Thanks in advance for the help!
