P
polarity
Member
For those of you using mixers or anything with EQ option before your DAW. How do you record, do you set your EQ on the mixer then record or do you set it flat, record it and EQ with the DAW?
I got the Allen & Heath ZED 10-fx and am trying to figure out the best practice. I would *think* EQing in the DAW would be better simply so I could modify it over and over instead of being stuck with the 1 take, but at the same time if I EQ it properly on the mixer I would be recording such a better sounding track. Then maybe re-EQ inside the DAW when putting it in a mix?
As a side note (and I havent searched this yet, I will when I'm done posting but I thought of this as I was typing). What good books are out there for learning the art of mixing. How to understand proper EQ and compression, how to set things into their space properly, etc. I would need something pretty basic just because I don't know much yet.
-William
-William
