PTravel
Senior Senior Member
I defer to the pro and stand corrected.But anyway ... your comments about pianos are wrong.
there are a lot of common misconceptions about piano tuning. so no problem.I defer to the pro and stand corrected.![]()
I don't record a single dry stereo track that I then put on CD. My music consists of multiple tracks, frequently dozens of tracks, to which I apply a variety of effects as needed and then mix down to a stereo master. It seems to me that the greater the "granularity" of a single track, the more likely it is to distort or produce unwanted harmonics when effects are applied and it is mixed with other tracks. I have heard the difference on vocal tracks processed with Melodyne -- 16-bit, 44.1 KHz tracks absolutely will generate more unwanted, non-existent-in-the-original harmonics than 24-bit, 96 KHz tracks when pitch-shifted. I also frequently wind up playing with the length of sustained notes, both vocal and instrumental. Whether stretching or shrinking, I've found that fewer samples of less depth produces a harsher sound than greater samples with more depth. Another extreme example: I've got one song that opens with the sound of a ticking clock. I had sampled the "tick tock" sound about 20 years ago with an Ensoniq Mirage -- an 8-bit sampler. Applying reverb to the clock sound to get a sense of depth resulted in completely bizarre harmonics and distortion when I tracked it at 16-bit/44.1 Khz, but a nice, natural sound when tracked at 24-bit/96 KHz.
I simply can't think of any reason why I would want work in anything other than 24-bit/96 KHz.
Everyone has certain equipment, software, plugins, settings, etc. that sounds subjectively better to them compared to something else. That does not mean the objective math and science of bit depth and sample rates is wrong.
mathematics and engineering can't always measure everything.
I agree with you completely. However, I don't think the sole metric in choosing sample rate/bit depth is whether a wave file encoded at a lower rate/depth would "null out" one at a higher rater/depth. I simply don't see how manipulation of sound through application of effects and other processing prior to mastering is going to yield identical results regardless of sample rate and bit depth and, indeed, I can readily hear the difference with some kinds of processing. I'd welcome an explanation as to why I'm wrong, but I haven't heard one yet -- only that the human ear can't detect the difference between two wave files, one at 16-bit/44.1 KHz and the other at 24-bit/96 KHz. I'll accept that it's true, but it's not relevant to my concern.As far as I know everything physical can be measured, and certainly everything that can be heard can be measured. Now, there are limits to how far below the noise floor we can measure a signal, or how high up into the GHz range an oscilloscope can work using current technology. But audio is relatively low tech compared to that stuff. Think of what's involved to get a clear photo image of the surface of Mars back to earth! Further, a null test can provide absolute proof that two audio signals are identical. If someone believes that, for example, playing Wave files from different hard drives sounds different, this can be determined with 100 percent certainty using a null test. Whether said person will accept this as proof is another matter entirely! But it's still absolute proof.
--Ethan
--Ethan
Measurements can't always determine what sounds "good" to individuals.
that one's a shocker to me ..... I have one and I find it almost unusably nasty sounding. Just a metal can sounding reverb at its very best.On the other hand, I don't care if the numbers prove it's noisy and the low bit rate is icky, I like my little Alesis nanoverb better than some more expensive boxes for some things (live female vocals for one) despite the spec.
....my right to be arbitrary on which I want to measure and which I want to use ears on!
.....so there's an underlying suggestion that better numbers should equal the better choice.that one's a shocker to me ..... I have one and I find it almost unusably nasty sounding. Just a metal can sounding reverb at its very best.
I use it in one situation where I have to set up two sets of gear
when I've got two solo gigs back to back in different locations and it's better than no reverb at all but only barely.
Acknowledging that we can still prefer something with "less fidelity" often sounds like someone saying you're free to make a choice...but your choice is the worse of the two..........so there's an underlying suggestion that better numbers should equal the better choice.
That's that part I don't agree with.
However, I can still prefer the thing with the inferior numbers in some instances, and THAT is the point.
However, hearing a difference between 16 and 24 bit recording? Highly controversial. On something like that, I'd rather depend on blind testing since it's so easy to convince myself that I hear differences that aren't there. We've all done that--I refer again to Ethan's video. Whatever you think of Ethan, the video makes some excellent points (and my psychologist wife confirms them for me). I don't want to delude myself with differences that aren't there and I don't want friends wasting money on $300 power cords that don't make a bit of difference in blind testing no matter what you thought your heard the first time you plugged it in because you desperately wanted to think you'd spent that money well.
Does that make any sense?
If any of it made a night and day difference, there would be no discussion.
Of course a higher sample rate will give you smoother pitch shifting and time stretching. That makes all the sense in the world when doing that sort of processing. A lot if the better plugins will upsample as part of their process for that exact reason.
That doesn't bother me. What bothers me is when someone prefers one thing over another when there is no difference.
