JimmyS1969
MOODerator
Love it! lol
Un-subscribed....
See you guys in 23 pages. I'll come back to make sure everyone's still going in circles with this.
I told you it was a shitty title for a shitty topic. The corpse of the horse is now decomposing.
(What Johny says about the lack of a blind test is 100% true by the way)
OOps....Just realized this is the wrong thread. I thought I was in the "debating analog and digital" thread. Not that this thread hasn't become stupid, but it's not the one I thought it was. Wrong stupid thread.![]()
It seems likely that you are wanting to hear a difference to validate your decision to use 96kHz (sub-consciously, of course).
But that's just the thing....I don't use 96kHz.
I only said IF wanted to, it would be my preference based on what I was perceiving. There's NO need for me to do "null tests" and "double blind" tests to have a preference. It's a subjective thing....don't you guys get it?
When you pick 2-3 mics out of the locker....do you do a "double blind null test" to decide which one to use or do you just go with your preference based on what you are hearing at the moment?
Do you do double blind null tests before making any/all decisions about anything/everything you are doing in the studio???
I don't know about some of you guys, but I'm not running a lab experiment in my studio....I'm just trying to make some music.
Oh...I use 88.2 kHz with my converters, but I also use 44.1 and 48....depends on my mood.
).In answer to your question, I don't perform scientific studies before making decisions about this kind of thing. However, when I first started out, it was useful to know that due to the Nyquist-Whatshisface theorem, I didn't need to go up to 96kHz or 192kHz to get a quality recording (my interface goes that high - it must be useful, right?!?!). A quick Google later and I was able to settle on 44.1kHz as a decent starting point without needing to break the HDD-space bank too quickly. I don't see any need to go higher - my limitations are not my sample rate (i.e. garbage in = garbage out).
when math becomes SO important for just 1-2 aspects of that subjective decision making process.As I improve (assuming I do), sample rate might be something I come back to mess about with. Right now, it's not the place I'm going to get the most mileage from.
I just did some 24bit recordings (used to do 16bit) and the difference is amazing! I feel like an idiot for not going 24bit in the past. Anyways, I'm wondering if it's worth recording at a higher Hz than 44.1? I've read that Hz don't convert down as well as bits, when formatting back to CD levels.
Thanks,
-Adam
Aren't you happy? 24bit is a big improvement. The Hz does matter. Since the CD will be 44.1 It is better to set it at 88,2 than at anything not divisible by 44.1. Otherwise there is dithering to get it to 44.1. Now here's a kicker. A major engineer did an upsampling from 16 to 24bit. The sound actually improved. Even on the bench you could see it was better. He had no idea why...it just sounded better.
Remember while recording to watch your levels, make every9one play as luod as they can while setting the levels and if necessary put a limiter on the input to protect your headroom. We thrash it out for a minute while setting things just below "0" and the tracks sound sweet when we use dynamics. Good Luck
NewYorkRod
NewYorkRod
if you can HEAR a difference between 16 bit and 24 bit, you're talking yourself into it--sort of an aural placebo effect. The only difference between 16 bit and 24 bit is the dynamic range available. The actual sound at the levels you can actually hear is identical ... upsampling from 16 bit still leaves your tracks with the dynamic range you started with
Well the link that will explains everything including the testing system is:
24/192 Music Downloads are Very Silly Indeed
For people that just want the straight forward nswer:
Tweakheadz · 16 Bit vs. 24 Bit Audio
Moulton Laboratories :: 24 Bits: Can You Hear ?Em? 96 kHz.: Can You Hear It?
Boom
NewYorkRod
having been a piano tuner for forty years and one of the busiest piano tuners anywhere (3-5 a day 6 days a week for the last 20 years of it before I moved to Florida a few years back) and having tuned pianos for symphony and large touring acts I can definitively say that is totally wrong.Pianos use 3 strings each for all notes but those in the lowest register. Anyone who knows acoustic pianos knows that a talented piano tuner does not tune each of the 3 strings exactly to pitch; leaving a miniscule amount of difference in the tuning of each string causes them to "beat" against each other and it is that which produces the characteristic piano sound. That's why professional piano tuners, the ones who tune for symphony orchestras, don't use electronic tuning aids but still rely on tuning forks that provide the pitch they match by ear. The difference amount between each string must be miniscule -- a matter of 1 Hz or less -- or the piano will sound out-of-tune. .
