J
jaynm26
Did Mastering comp figured we talk bout EQ's now, what's your EQ's you use why you like them? If any mods please do tell.
Crane Song Ibis -- It's the regular one, but I had Sean mod it for me -- First, it's matched up better than just about any Ibis on the planet. Second, the swing is +/- 6dB like the "M" version (instead of the stock 12).
Dangerous BAX -- Hell, I bet it's the only piece in the rack "as-is" from the factory. Surprisingly, probably used on nearly every project that comes through (along with the STC-8M).
The EQs I'm using now are GML 8200 - Bax (hardware) and RenEQ (software)
I got the GML because I used to have this equipment dealer who would just drop stuff off for me to check out and if it was awesome I would just let him know he couldn't have it back and in turn, I would have to pay for it. I'm in no hurry but will most likely swap out EQ's this year.
This is the new Eq I'm looking at getting: Knif Soma EQ problem is it's a little expensive. (8K)
If I need more than 6dB of -- anything -- the mix has bigger problems than which EQ I'm using. The +/- 6dB gives me much finer control over the "important" range.Explain the moded swing please massive?
OhhhhhhIf I need more than 6dB of -- anything -- the mix has bigger problems than which EQ I'm using. The +/- 6dB gives me much finer control over the "important" range.
I can tell you one thing that still stands with me -- And this is where the "if the plugs were as good as the hardware" thing comes in --
I don't (didn't) use Pultecs often for mastering (although if you had a pair that would actually pair up nicely, I wasn't against in by any means and sometimes it's really the only thing that will do). Several years ago, I bought the UAD Pultec (actually at the time, I believe it was part of the package). That plug to this day is (IMO) the best hardware emulation of anything I've ever heard. I don't miss hardware Pultecs one tiny bit with that plug handy.
That said - I don't know if I'd ever actually consider them a "staple" for mastering engineers in the first place... But no doubt, they have a wonderfully unique quality to them (even just switching them on - And that was the first thing I found with UAD - They captured "that sound" a Pultec has even with it zeroed out).
