In my opinion you should forget using both mics for now and focus on getting a good sound with one.  I would start with the KM184 and point it more toward the sound board or the hole, striking a balance between the two by way of positioning.
It always interests me why it is a common approach to mic the 12th fret of the instrument.  I would never do it this way simply for the fact that all the sound we hear from an acoustic guitar resonates from the sound board.  Conventional internet "wisdom" is to avoid mic'ing close to the sound hole because the sound will be too "boomy".  This is often nonsense.  Granted, you generally don't want to put a microphone right in there because yes, the lower midrange is definitely a bit more pronounced but if you move the mic around the sound board whilst capturing a BIT of what's coming out the hole, you can achieve a good acoustic guitar sound.
Another thing to know about acoustic guitars IN A MIX, is that is is common practice to cut out a lot of the low end, compress it to a substantial degree, and to address how much top end you want to be heard.  This is due to the fact that the acoustic guitar fills up quite a huge amount of the spectrum and will fill a mix very quickly.  Note that is this is typically the case in full mixes where there are other instruments competing for space.  The general rule of thumb is that the more sparse the music, the less attention is given to the acoustic guitar.  For instance, in music where there is just acoustic guitar and voice you would want to keep the guitar nice and full.  For other music where there is lots of instrumentation, it will require more attention.
