S
sidecarjoeg
So I'm in the market for a new mixer. Right now I am using 2 Layla 3G sound cards on my PC which give me 16 analog ins and outs. They sound great and have no desire to upgrade here right now. I'm currently using a Mackie 1604VLZ Pro mixer to get tom tracks pre'd up and run the direct outs to my Layla boards. I then run outboard mike pres for most of the rest of the drum mikes direct to the Laylas We run a rough track bass/guitar direct into the Mackie and also to my Layla which gets re-recorded later however we want it. We use the aux send busses to feed different mixes for headphones for each of the musicians (including myself as the main band member). We currently have an additional mike on the kicks so we can get those into our headphone mixes. With all of this being said, I'd really like to go to a 32 channel mixer that ideally has the B mix structure for mix down time. That way we can eliminate those extra mikes and I'll have everything there to send to the headphone mixes. So here are some boards I'm looking at right now. Keep in mind that I would like to keep around $1500 or less. And midi is not really important to me.
Tascam M3500/M3700
Mackie 32*8
Mackie Onyx 3280
Allen and Heath GL2400
Allen and Heath Zed 436 (if I can find one used)
Soundcraft Ghost
Soundcraft GB4 (if I can find one used)
Soundtracs Topaz 32 channel mixer
So basically my question is this: What sounds good compared to what, where would I be best spending my money? The Topaz is interesting because it seems to be available for relatively cheap. I'm not scared to use a soldering iron (I have fixed many Commodore 64s in my day and have done many other electronics projects in the past), so an old board that needs upgraded doesn't scare me. I want something clean and transparent with relatively low noise. What are your thoughts and experiences?
Tascam M3500/M3700
Mackie 32*8
Mackie Onyx 3280
Soundcraft Ghost
which in turn gives you 48 channels at mixdown....I could never part with mine and I have seen them on e-bay for as little as $1200 (Im sick) paid $7000.00 for mine !! GET IT if you can find you one
