U
Unclejohnny
Except for the giggles.![]()
The giggles are a giggly 16 yr old, my son's gf.
The giggles are a giggly 16 yr old, my son's gf.![]()
how to turn off the anti-virus stuff, firewall, etc.
Is there any chance that any of your cable or connector may be loose?
Try to record in audacity or any other software.
I record at home at my 2006 PC with a $3 headphone mic. and only noise i get is static noise. I am surprised to see that there is same static noise in your recordings too. What kinda setup do u have?
RitB
A small update...
I've now had a copy of the original file and it's not an "ordinary" problem of glitches. The big "wavy" waveform actually appears to be the zero crossing point of the file that's normally a nice flat line in the middle of the display. Despite the strange appearance, it's still modulated with the voice recording which (amazingly) still plays back. Think of something like a DC offset but with alternating current. My only guess is a fault with the USB bus on the laptop allowing extra current to get into the data stream--but I have no idea if this is likely or even possible.
It's not something I've encountered before so widened the net and asked a few people not on this forum if they've ever seen anything like this. As frustrating as this must be for the OP, it's an interesting puzzle!
Anything is possible!
FYI, I've just had a first suggestion back from one of the people I asked (an ex BBC engineer). He says it looks like what happens when a bad case of mains-borne interference is recorded. Is there anything with a heavy duty motor or similar that could be putting some big interference back into your electrical supply? If so, maybe your interface is picking that up and recording it.
...and that Scarlett interface is bus powered, isn't it?
If so, I'm back to wondering if there's a fault on the bus power being supplied by your laptop. I don't suppose you have an old laptop you could try (or perhaps borrow another one for a test)?
The reason people aren't hearing the LF interference is that it's below their speakers range and outside the audible spectrum.
