bouldersoundguy
cut off everything under 50K.
That would be the whole audio spectrum and then some.
Nice, Jimmy! Thanks! (and it's a Focusrite interface so I'll already be on that website for the driver!)I recommend HERE for instructions
LOL... sales might decrease a little...
What does it sound like? Post a sample please.![]()
I must say man, all I heard was typical background noise on a track that has gain up way high.
Are you sure your zoom level of the waveform is just not too big? I don't hear anything abnormal here.
Hi OP,
I may have missed this, but have you provided a description of the actual equipment in use, and whether the computer is a desktop or laptop?
I'm wondering about some sort of electrical interference or grounding problem.
Paul
That's just the thing, there's no sound. I think the fluctuation is coming from something electronic inside my gear. The gain level is fine for my normal recording of voice over for on-hold. If I'm speaking when one of those silent bursts pops up, it gets laid onto the crazy contour. It the peaks are not too high, it's okay, but on the larger ones, voice will drop way down or break up.
When they erupt while I'm speaking, there's distortion and stuff but if it happens while I'm pausing and it's quiet even though the line jumps way up and down.
(I tried to attach an mp3 from the original screenshot but it's too large and even when isolating pieces of it, the site won't let me load them-too big.)
Right...I have a bit more time for a longer reply than my first, rushed suggestion to check the drivers.
First off, Audition. Since the problem is being recorded, it's highly unlikely that it's any setting in Audition itself. Unless you're doing a sample rate conversion (a bad idea anyway) Audition doesn't get involved in the recording--it just passes the data output of your interface straight onto your disk. This question came up before and I actually confirmed this with a couple of the Audition developers at Adobe.
Second, most electrical interference is superimposed on top of the material you're recording; your problem looks to me like the programme material is interrupted with some kind of strange noise rather than the noise over top.
For this reason, the culprits I'd be looking at would be a fault with the drivers (which I gather you've already tried) or some process in you PC intermittently upsetting the orderly flow of data to your disk. For this reason, those suggesting you go through and optimise your PC for recording could well be on the right track. Shut down all networking, wifi connectivity and anti virus software as a starting point then work through all the optimisation suggestion.
If none of this helps, it could possibly be a hardware fault in your interface--I hope not because the chances of an economic repair are pretty slim. If you can beg borrow or steal another interface to try, it's probably a worthwhile experiment.
As always, make sure all your cables (XLR and USB) are okay--though from the appearance of the problem, these wouldn't be my prime suspects.
Well, there IS sound but almost all the energy is in the 0 to 50Hz range so probably not hearable in most conditions. except for the very LF stuff, most of the background noise is down around -70dBFS or lower.
