S
singer202
Is there a mic placement that you find favorable for helping decrease the amount of Ess coming through? I dont like smashing it too hard with de-essers afterward....
I automate the volume to remove a little end-of-word ess. .
One handy trick is to tape a pencil to the grill of the mike like this:
It diffuses the energy of toppy bursts like esses from the middle of the diaphragm, where the mike will be most sensitive to them.
Hope that helps.
Cheers![]()
Miroslav, how did mjbphotos morph into "jabots" ?Right...that's the same thing I do
Is there something we should know ?![]()
I've heard of that, but not for sibilance. Sibilance is more a frequency kind of thing. The pencil "trick", if you can even call it that, is supposed to be more for plosives - like hard P and D sounds. That's the way I remember it anyway.
Well, microphones (especially condensers) are more sensitive to sibilance in the center of the diaphragm where there is the most play. Towards the outside of the diaphragm it is stiffer and therefore more robust to it. The main aim of the pencil "trick" is to diffuse the higher energy (the esses) from the center of the diaphragm and create an indirect pressure wave.
But yes, it could also help for plosives as well.
