Cool. I don't mic my toms. Just 4 mics: Snare kik and 2 overheads. With the right placement, room, etc....you can get a good sound. I have to admit that my toms have sounded a little weak in my last couple of recordings, so close micing probably wouldn't have hurt. But my skins need to be changed, so I blame it as much on that. The point being, how drums sound before they're miced is much more important than which mics you use and how many of them.
I actually mic everything when tracking, however I don't always use every mic when mixing. I find that the kick, snare and overheads are the main drum sound. I sometimes gate the toms (even though I am not a big gate fan) so that when they are hit there is a volume increase if the tom was hit too soft (blame the drummer) however another method that works is to volume / mute automate so that the tom mics are only open when hit, this works better on builds where gates don't open early enough to let the soft hits through.
One mic I always gate is the mic I put under the snare, just to keep the snare rattles out of the mix.
Just a few clarifications on my method:
1) all the drum mics have to be checked for phase problems before hitting record
2) the drum sound should still be good if all the mics are on
3) the drum sound should still be good if some of the mics are off
4) the drum sound should still be good if only the kick, snare and overheads are on
5) if the drum sound is no good start with the room, then the drums (tuning, skins, player) before reaching for the eq, gates, compressors.
6) when using eq, the only drum that should need eqing is usually the kick, maybe some minor eq on the other drums with a bit of clean up eq cut (no boost) on the hats and overheads
And, the method of getting the drum sound also depends on the type of music being recorded and the desired final drum sound, this should be decided at the recording stage not the mixing stage.
Alan.
