bouldersoundguy
I just time align by hand/ear/eye. No plugins are needed. Once you've done it a couple of times you get fast.
Move the overhead track next to the track you want to align to it, zoom way in on the timeline and magnify the waveforms. Solo the tracks and find a distinct hit on the close mic. You should be able to see the offset. If there is a polarity mismatch that should be visible as well. If there are punches or edits you may want to group or consolidate the track so it all moves together. Then manually slide the close mic track to match the overhead. If at all possible do this while the two tracks are playing so you can hear the results immediately. Fine tune by ear, trying it with them hard panned apart and both panned center. Adjustments will be in the 2-5ms range.
Repeat with any other drum tracks bleeding into the overheads.
If you used a spaced pair of overheads then any drum not centered between them won't match up with both so you have to choose which overhead to line it up to. In your case match the snare to the overhead with the most snare bleed.
In general this tightens/fattens the tone. It may change it a lot or a little. You might like it or hate it, or not care either way. Base your decision on how it sounds, not on how it looks. Be prepared to undo your way back to where you were should the results not make you happy.
. I can see that the Snare is a bit earlier than the OHs, so I can still line them up. But, Issue.... On a stereo track, would the top or bottom string be the right side?
