Some hardware mixers put the eq before the insert, which I prefer. Most DAWs I've used just treat the eq as a generic insert, allowing it to be anywhere in the order. If I had to use a DAW with the eq locked at the end of the inserts I would bypass it and insert an eq plugin where it belongs, before the compressor.
Yeah this is probably what 98% of cubase users do. I almost never grab the channel strip eq for anything. I have to many other neat eqs to bother with the boring stock 4 band.
Guys, inserts 7-8 are post-fader and therefore post-EQ. This is one of the niftier features of the cubase mixer in case you want to use the track EQ before an insert or use the fader to push a track into a compressor, etc.
Yes, but then you face the problem that the compressor can be overreacting to frequencies you've cut and under-reacting to frequencies you've boosted. If you apply a high pass filter the compressor still reacts to the low frequencies making the mids and highs bounce around for no apparent reason. Lighter eq, especially in the HF, works pretty well either way.
Exactly. Remember a wideband compressor does not discriminate. If you're feeding it a signal that has too much of a certain problematic frequency range, it will amplify the problem. I almost always do my surgical EQ before compression to avoid this and then later if I need any tone shaping I'll EQ again.
