B
BluesPills
Hello, I am a newbie when it comes to analog machines. I just bought a Tascam 488 mkii, the problem is the channel two seems to be dead or atleast almost dead for both the incoming signal, and playback.
when i plug a mic in if i have all the levels cranked to maximum, its barely audible... but every other channel is fine
and then when I play back a tape which has something recorded on track two, once again its still there but you can't hear it unless you turn everything else all the way down, and channel two is blasting, and then still its extremely quiet..
any ideas on where to begin to find the problem will be much appreciated, i live no where close to any electronics repair or anything so I am going to need some help in the right direction.
thanks
thanks
