R
rimisrandma
Guest
On the Presonus firestudio mobile, I looked over the manual and noticed something. If you have a piece of equipment with stereo +4db output and run it into the line inputs on the Presonus FM, there is no level/input/trim control. It states the output or volume control on your piece of equipment will set the level.....................Does this matter because whit if you want to run your equipment 2/3 or 3/4 all the way up to get a good signal and then tame it down with the interface trim control.........In this instance you would not be able to do that, but does this matter or an issue when running equipment into the LINE INPUT jacks?????
