miroslav
Cosmic Cowboy
Did you ever pick the amp head off your cab and find that the black rubber feet from the head left marks in the Tolex...?
Small indentations & smudges...and on lighter colored Tolex, sometimes black stains from the rubber.
I found a simple way to prevent this from happening.
You go to the hardware store or auto store and pick up a small roll of 1/8" cork (used for making gaskets).
Find a round object (jar lid or whatever) and with a pencil draw circles on the gasket for as many rubber feet that you want to treat...and then cut them out with scissors.
Use a rough piece of sandpaper to smooth out the cork edge as cork cuts a bit rough.
Place the cork coasters under the rubber feet.
In addition to protecting your Tolex...the cork also makes for better grip, so the head won't slide as easy as it does on some types of Tolex.
You can make the cork coaster in any size you need, and they are great for other things too...between other gear surfaces or anything you want to protect.
Of course, if you move your amps around a lot, like for gigs and what not...it might not be worth your while...but for studios and home use these are quite handy. There are probably a lot of other uses for them.
