miroslav
Cosmic Cowboy
Lance
I don't doubt that the polymer is sealing and polishing the tape....same thing it does to the hood of a car.
So yes, you are putting a coating/seal OVER the SSS.
Now...maybe(?) that's all that is needed to "cure" SSS, but I'm not convinced just by that.
I mean, you could put a polymer coating on a rusty piece of metal, and the rust will not "come out" since it's sealed inside...BUT...is the rust removed/cured...?
NO.
Maybe by sealing it you feel it's cured, but I see the sealant as just a casing over the SSS problem. The real question comes back again to what is happening at the molecular level, and up to this point, you've pretty much pushed those considerations aside and are already convinced just by what you can observe on the surface that you've found the cure.
I don't really feel that's proven science. Maybe it does cure/solve the problem...but I think one needs to take a really, really close look at the particles and other chemicals with a microscope and see what happens to them when the seal is placed over them....and then study them over time.
Is there s-l-o-w chemical interaction that is not visible by the eye?
Not to mention...is there any damage happening to the deck transport, heads, rubber rollers...etc....at a microscopic level as the tape coated with polymer, rides back-n-forth over, and over, and over, and over...well, you get my point.
Heck, my Otari 5050 BIII 2-track deck has non-metallic (not sure if they are plastic or some other material) "rings" at the ends of the metal guides...and other decks might have them too. How will they be affected???
I'm not about to rub a non-approved, untested concoction across those guides and assume over time it won't damage them or my heads. Not to mention, erase heads are very often PLASTIC on many decks...so how will they fair over time???
Not to sound snooty...by just having to replace my head-stack and guides would probably cost more than 2-3 of those TEAC 2300SD decks on eBay.
So unlike some home-rec/tape heads who have throw-away tapes and old, antiquated decks...I'm not about to shit up a practically brand new $6k mixdown deck experimenting with chemicals, and that's the same attitude you will find on pro audio forums where people still use expensive tape decks for recording and/or have tons of old tapes with big-name music on them. Those folks are not going to risk that stuff based on a few forum posts.
You think someone will risk a 24-Channel Studer with chemicals that are not yet recommended by anyone in the industry other than you and another guy on some home-rec/tape head forum....???
Win over those pros, and then maybe you will have something....but I guarantee that won't happen without formal lab testing and real science.
Oh...and I have no need or desire to post on the tapeheads forum. I see you've won over a handful of "I think I'll try it, I have nothing to lose" types over there (though there are skeptics there too), so why would you want me to post there...?...just to get into another drawn out meaningless debate?
I instead again say to you that you should post your comments on the a couple major pro audio engineer forums, and see how that goes.
You have to consider that SSS has been around a LOOOOOOOOOOOONG time, and lots of guys in white lab coats at the major tape manufacturing companies (when they were all still in full swing) have tried to find a real *cure*. I would not be so quick to dismiss their efforts and to think that somehow they simply "missed it"...that they just didn't try the more obvious possibilities. Polymers/sealants are not new...and companies like BASF have been playing with chemicals for a VERY long time.
Don't forget to rinse out your kitchen sink...
NO.
