W
WyndBalduram
Hello all! I have a question.
Why am I getting a heavier bass response from my mixed down track than I have with the mix in the box (I am using Studio One)?
I tailored my low frequencies with EQ to be responsive and not overpowering or muddy(particularly in the bass guitar and kick drum) - sitting where they need to be in the context of the guitars and other instruments.
After using Studio One's mixdown function and listening to the track (both in Winamp and Windows Media Player), it is as if the bass is boosted slightly and loses some of its definition, and is overpowering.
I am doing my actual mixing in 44.1K @ 24 bits. I am mixing down the track to 44.1K @ 16 bits. Is it the loss of bit rate that is causing the low end to sort of pile up on itself instead of remaining defined the way I EQ'd it?
To compensate I toned back the EQ on the bassy stuff a little bit to try to get a less boomy result, but ended up taking a little of the life out of the low end.
Any ideas on how I should approach keeping my low end (and entire track in general) to sound at mixdown that same way it sounds in the box?
