JimmyS1969
MOODerator
Man - after reading this thread - I think I need to take a course in Cubase :X
Cuts and cross fades? I dunno what that crap is! Unless you just mean cutting up the wave file in the track? And cross fade - thats like fading one wave down in volume as another comes up in the same track right? I don;t think I have ever had any need for that...![]()
Yeah, I get pretty damn anal about timing and background noise issues. When tightening drums or guitars, I use what is called 'slip editing'.
Say a part is played slightly early or late. For this example, an accent combining a kick hit/cymbal choke and a bass note. The last bass hit is late. In the arrange window, select the event (waveform of the area to be fixed). Use the cut tool to slice before and after the late bass note. Select that section (left click). Hold down Ctrl and Alt, hold left click and slide the waveform to the left until the part is in time. You will soon learn specifically where to make the cuts after playing with it awhile (if moving left, the cut needs to be placed slightly earlier to allow the 'slip' to move to desired place).
In most cases, especially when there is a sharp change in the waveform, this will introduce a 'click' in the audio. Hold Ctrl and left click the events on either side of moved section to highlight them. Then hit Ctrl X (shortcut for crossfade). Now the 'click' will be gone. Well, usually. I will actually do all of the slip edits first on whole track, then select the whole thing and do all crossfades at once. It is very important then to listen to the track closely, usually solo'd in headphones, to make sure there are no clicks or double notes or whatever, before bouncing the track. After you bounce, you can always fix more. Bounce in this case is used to 'clean up' the mess.
Make sure that if you have multiple sources for say the bass (direct, mic 1, mic 2), that you place them in a folder and 'group edit' them. Not sure how this works in earlier versions but all bass tracks would need to be selected and slip edited at the same time or extreme chaos would result.
This might seem a bit complicated at first, but it becomes second nature very quickly.
Happy slippin!
Jimmy
