Eleanor Fudd
Member
if you want to? [Say, if you bought a superior preamp.]
Thank you.
Thank you.
if you use xlr to 1/4" you'll have no preamplification (<- that should be a word)
thanks for thatIt IS a word now.
Could you not plug the mic into the independent preamp, then the preamp into the 1/4" analog input?
Thank you, that seems a good answer.
I was thinking of this one:
8 in / 6 out USB 2.0 Audio Interface featuring two Focusrite Mic Preamps
The blurb says: Alongside the two high-quality mic preamps, two additional analogue inputs, four analogue outputs, S/PDIF and MIDI open the door to true multi-track recording.
I will assume that bypass is not likely possible on that one. Will a XLR to 1/4" adapter allow you to go into one of the other analog inputs, and do the bypass THAT way? [This is a matter of future-planning and understanding. I'm not assuming any problem with the interface.]
Thanks again.
Are you talking about using an outboard pre into those inputs?
Well ... that's pretty much what the two additional analog inputs are for, isn't it? That is: to route analog inputs to the interface and bypass the mic pres?
If you're so inclined, you could even get a standalone AD converter, connect the mics to a standalone preamp, the preamp to the AD converter and the AD converter to the interface's S/PDIF in, and bypass the mic pres and the converter in the interface.
The connection to the computer?What is an interface but A/D converters and connections?
Perhaps you (or whoever it was who bought it ... Eleanor Fudd, possibly) did want to use the preamps when you bought the interface, then later on, say, you bought a superior preamp.
Such things happen.
